Days Won
174
Everything posted by haumana
Weeding issues, pieces not staying on backing paper
haumana replied to Emchavez1's topic in MH Series Vinyl Cutters
Very true. If the vinyl feels a little crispy/brittle/stiff, then while it might still be usable (for personal projects), it'll make for some challenging settings to cut. -
[Can anyone help me find drivers for the GCC Jagaur II 61 cutter. download or buy] I found this. Hope it helps. [Ich habe das gefunden. Ich hoffe es hilft.] https://hardwaredata.org/index.php?driver=25919
It looks like you're getting some really clean cuts. First and foremost, make sure you have the correct blade depth. Follow Skeeter's directions that she posted above, and then go from there. It's a bit hard to give you a precise setting to use, as every machine will be different, as well as, type/brand of blade, age of blade, brand of vinyl, age of vinyl, and sometime vinyl color (yes, even it's all the same Oracal 651, or whatever brand and series you use). Try to weed your vinyl shortly after cutting, as there have been instances if you don't weed it - the adhesive can bond back to each side across the cut line. I will generally weed within 48-hours, if not immediately after cutting. If you're not going to weed it immediately, make sure that the vinyl stays fairly cool, so the adhesive doesn't get gummy and re-bond across the cut line. If when weeding, if it seems that the blade has not cut through the adhesive, then you might need adjust your blade depth and/or pressure. In your case, it looks like pressure, since you're getting some clean lines. Not going to lie, when I got my first machine, the US Cutter guy told me that the starting pressure for my machine was 120. That was the quickest way to cut through the vinyl, the adhesive, and almost clean through the paper backing. It took a little trial and error, but the sweet spot for pressure for my first machine was between 86 - 105 (depending on vinyl age, brand, and color). As long as you're not cutting through the paper, you can up the pressure a little at a time. Once you start to see the blade cut into the backing, then you know you need to dial it back a little. There have been times that I have cut the vinyl, but not the adhesive, and it's a total pain to weed because it just wants to pull everything up You can use the control panel on your machine to do test cuts. If I'm not sure about a setting, I will run test cut, after test cut, after test cut. I will know the sweet spot when I weed it all up and see what how well the paper backing was scored (or not). Last, but not least, take your time weeding. I will typically use a skinny bamboo stick with a rounded point while I'm weeding, just in case there are pieces that want to lift as I go. I just hold down the size that's wanting to lift to hold it down. If you're having difficulties weeding because what you're trying to remove is kind of big, then you can cut boxes around areas to make them smaller and more manageable. -
I won a Summa Sign D1010 at auction, I don't know anything about it.
haumana replied to GaltsGarage's topic in Competitor Cutter Help
I do the cut & paste method, because I want the cutting carriage to stay in the area and cut twice before moving to the next section, minimizing the material from going back and forth. It's a LaserPoint, no where near as precise as a Graphtec. It was either Dakota or BannerJohn who advised me to go that route. -
If for some reason the reflective isn't cutting quite like it should, then you might need to cut it twice. I have not cut reflective on my Graphtec, because I don't want to abuse my new CleanCut Blade that way , but when I do cut reflective on my LaserPoint, I find that it needs to be cut twice. The trick to that, is cut and paste the graphic so that one sits directly over the other, and the machine will typically cut the first pass, then cut the second. -
Vinyl cutter recommendation for a university makerspace?
haumana replied to ericdmj's topic in Pre-sale questions
Nice! There really was no bad choice. Sounds like y'all have a great game plan and the money to fund it. That sounds like a total win in my book. -
copy > paste > edit out the nodes you don't need until you're left with what you're looking for.
Welcome to the community! It would be helpful if you posted a pic of what you're trying to weed, and if it's a close up, put a coin or ruler by it so we have something to reference for size. Another means of weeding, which some crafters and hobbyist do, is to weed what you can, tape it up, and then weed the rest from the application tape. I am not a big fan of that personally, but admittedly there have been times where I thought I weeded it perfectly, only to find out that there was something I missed, and needed to weed it off the app tape. It happens -
VinylMaster Spooler not responding
haumana replied to Over the Hill's topic in VinylMaster CUT, LTR, PRO & DSR
Win10. The bane to some people's cutting life. There is a chance that Win10 (automatically) downloaded an update that has unknowingly caused the connection to be hinky. If you have access to an older Win7 or WinXP, I would try with that. If you don't, then at the very least, take your Win10 machine offline. I don't know if it's worth the hassle of deactivating the license, and trying to reinstall, or just waiting to see what VM has to say about it. A possible workaround, is as what Skeeter has suggested, download and install SignBlazer and at least get your machine going until you can figure out the issue with the VM/Cutter spooler. -
SC2 not feeding vinyl properly
haumana replied to Xc2139's topic in SC Series Vinyl Cutter Discussions
try cutting a square box and see if it gives you a rectangle. are you able to run a test cut from the cutter control panel? -
which directions are the ovals? longer front to back, or side to side. -
Aloha e Bryan. Welcome to the forum. It's super quick, easy, and free! I would suggest you register as a forum member, that way your post show up immediately, and it won't be delayed waiting for one of the volunteer moderators to approve your post. Now on to your original question, this video might help you or at least point you in the right direction.
- 1 reply
- 1
What OS are you running? Is your laptop staying put, near the cutter, or are you plugging and unplugging the cutter on a regular basis? You might want to check which port the cutter was assigned to, and make sure that VM is selecting the correct port.
^THIS^ Definitely that. Because an incorrect blade depth will cause frustration and possible unnecessary wear and tear. Oh, and maybe an extra cutting strip or two. -
Ummm, what exactly is your question?
So for you accoutrements, here is what I would suggest - a new machine should have it's own set of everything if the original machine will still be on location, and in use. squeegees rotary cutter or some kind of x-acto or retractable blade decent pair of scissors some kind of aluminum safety ruler spare blade holder spare blades, or a very durable blade, such as the Clean Cut blades carrier mats USB cable Extra long power cable, if necessary That should be a good start. -
That's a 1st gen LaserPoint, I used the one of the Creation Pcut software 'driver' when I ran it on my older Win7 box, don't recall the specific one, but Kainth is probably right - I probably used the CT630 driver. I haven't dusted it off in a while.
Have you submitted a trouble ticket to VM?
The one advantage of getting a Graphtec, is the software that Graphtec will bundle with it. It's dual platform, and has an Illustrator plug-in that's supposed to let you cut directly from AI. Admittedly, I just import my vector files into SignBlazer if I'm in Windows, or the Graphic Studio if I'm in Mac, and just use those two for cutting, rather than designing. I have a friend who has a Titan 2, and they love it. I have an original LaserPoint, still going strong, as well as a Graphtec CE6000 (just wish that I got that a lot sooner ), whatever you decide, I don't think you can go wrong with upgrading to a different cutter with a larger cutting width. Good luck, and let us know what you decide! -
Vinyl Master 4.2 Upgrade To V5 Cost?
haumana replied to storm2313's topic in VinylMaster CUT, LTR, PRO & DSR
I am of the mindset - if it ain't broke don't fix it ... or the equivalent for upgrading operating systems and/or software. There's a reason why Skeeter still uses an old XP machine If I get my machine to work with a certain software, and it functions with enough features to support what I'm doing, then I leave it be. Though, with the new Windows machine wanting to force upgrades upon machines, that's a tough workaround, because sometimes an unwanted upgrade will break some functionality in certain programs, or no longer wants to support the peripheral devices. It kind of makes me crazy, but thankfully Microsoft will ensure that my IT consulting business will thrive for the foreseeable future. -
Hey Jeep - I have a CO2 Laser Machine. If you'd want a bottle/flask/rambler or cup/tumbler done let me know. I can do anything that's been powder coated (like the colored Yeti's, HydroFlasks, etc.), glass, or anodized aluminum. The down side to laser is that artwork works best in black & white format (as the laser beam is either on or off - because it doesn't do colors).
Sorry to hear that you lost a lot of your work. VM has a very basic ability to configure automatic backups, but maybe this will help. At any rate, if you keep your artwork and working graphic files on a single computer, I would suggest either subscribing to an online backup service such as BackBlaze or Carbonite, and/or get yourself an external drive to manually backup your files periodically. When I get desperate, I will have Explorer search the entire computer for anything with a particular file extentsion (ie. *.docx, *.xlsx, etc.). It might take a while, but it might point you in the right direction. Good luck. Where to open a possible backup file in VM: Default location for my VM backup files: File extension for the VM Backups:
This would be such an awesome tool, however, I think you might have to troll Google for Wordpress forums to get a better answer
Sc2 Cutter inconsistent and Rarely completed shapes of cut.
haumana replied to Sweetsassy85's topic in Creation PCUT Cutting Plotter Support Requests
thank you for updating us. it's always appreciated, and no doubt someone will find this thread useful.
