vinylmotivations
Members
  • Content Count
    1,226
  • Joined
  • Last visited
  • Days Won
    19
Everything posted by vinylmotivations
  1. vinylmotivations
    What cutter is best for me
    My old laserpoint would cut very very small text, you just have to be VERY accurate with your blade, pressure and offset settings- be prepared to spend some time learning to set up your maching for cuts using different vinyls, colors etc. Each color, and even rolls of the same color can require very very minor tweaks in pressure and blade depth.
  2. vinylmotivations
    hey trying to upgrade
    I too mirror the graphtec recommendation... You can use flexi with the graphtec... cutmaster2 and corel are just additional options....
  3. vinylmotivations
    CraftRobo CC330-20
    http://www.ebay.com/itm/EUC-Graphtec-Craft-Robo-CC330L-20-Vinyl-Cutter-/130733928281?pt=LH_DefaultDomain_0&hash=item1e70596f59
  4. vinylmotivations
    Vinyl on Gym Floor
    631 and 651 both work great for this use... cheap. Also have used scrap Greenstar in the past. Hesitant on finished wood though, unless it's very strong.
  5. vinylmotivations
    getting Cdr X3 and cutting master 2 to work together
    try uninstalling everything and go that route
  6. vinylmotivations
    I did- BUT- it was the version that came WITH my CE5000....
  7. vinylmotivations
    corel draw x4 not connecting to creation ct1200 plotter
    There isn't a way with that cutter unless you buy something like SignTools3 or 4- which allows cutting from corel on about any cutter. Otherwise Graphtec and Roland have specialised plugins that allow cutting from corel.
  8. vinylmotivations
    Used graphtec with problem, worth it?
    You can buy a new screen etc. for it.... Just call up graphtec. I ordered an LCD for my FC7000 - was like 102$- BUT- it's a 4 line display versus the 2 that the CE5000 has.
  9. Back the truck up a second here Not cutting that size doesn't make sense- I know... BUT- You have to eliminate ALL possibilities when you're troubleshooting. It still could be the file, could be a cutter memory issue, and it could be that it is needing to be spooled in pieces versus just dumped to the cutter. Say I have a graphic with 1,000 nodes- 22x14. If I expand that to say, 500% - I still have 1,000 nodes, but their more spread out now- the file size goes from about 2.93mb to over 8mb.... Could be that the file, in that size, has too many nodes for the cutter to handle all at once, and the software needs to spool it a little at a time- OR the other thing I found a lot of the time with my old Laserpoint 24- It could cut faster than it could receive... so once it ran out of nodes to cut, even though they were still coming it would go crazy and do dumb things. Things to try- - Slow down your cutter - this can also effect tracking and placement of weeding lines and letters. - Check or don't check "Use Spooler" under the cutter settings in SignCut - Try that Keyspan device you have coming.... - Try cutting without your blade in, and also use a pen tool on paper to see if you have the same issue- Static can cause goofy mess as well.... - Before perfoming large cuts, shut the cutter off completely to clear out it's buffer, this helps as well on machines with less memory. - They also make a memory upgrade for the MH series cutters- Seems to be that this fixes a lot of problems with this machine as well.
  10. vinylmotivations
    I think a new main board for a CE5000 is like 650$ - so it could cost a lot to fix even if it is easy. Also, if it doesn't have the original box- don't plan on shipping it to graphtec because they won't off any warranty unless you buy an obscenely expensive original packing box/crate (400 some $$) BUT- Graphtec is great to work with, they will sell and ship you parts and did nicely for my FC7000 that FedEx BROKE.
  11. vinylmotivations
    Last Nissan of this Saturday...
    what did you use to design that half wrap??
  12. vinylmotivations
    I am looking to expand asap
    If flexi 8 is the pro version, I believe you can contour cut using that software on any cutter, you just use the blade as your registration positioning tool. I am not sure how it works but hear that it does!
  13. vinylmotivations
    what transfer tape for oracal 651?
    Looks nice- No, the SPLASH fluid is an 8oz bottle that mixes with a gallon of water you provide... makes it small to ship, so you will want to order it with other supplies from USCutter... http://www.uscutter.com/SPLASH-Concentrated-Application-Fluid-8-oz-CLSSPL8OZ Get yourself some of this too- I LOVE it- for removing adhesive.... http://www.uscutter.com/Orange-Peel-Adhesive-Remover-GAPSAR409
  14. vinylmotivations
    I personally use the SPLASH! application fluid USCutter sells- I like it as much as rapid tac2. Rapid tac is about 30$/gal whereas the splash is only 12$.... The other option is, if you search there are several homebrew options... but I haven't liked them as much.
  15. vinylmotivations
    cutting picts
    The images you're using are probably on .jpg or .bmp / .png files- They MUST be vector format images before they will export and cut.
  16. vinylmotivations
    ZenBlack should be here today!!!
    Can you compare your experience to any other cutters or equipment in your past?
  17. vinylmotivations
    Take pictures/video???
  18. vinylmotivations
    Oracal 651 matte black issues
    Matte vinyls often are tougher as the vinyls don't have a smooth finish for the tape to stick to. #tapetosandpaper.... whereas gloss vinyl.... #tapetoglass... squeegee VERY hard from the back and this will help make it a little easier... Skeeter- I am going to pm you as well tomorrow.
  19. vinylmotivations
    I use rtape 4075rla myself. You can just use your Rtape and then just lay a couple strips. I would install wet, and squeegee WELL- then wet the paper tape to peel off.
  20. vinylmotivations
    Error Graphtec GX3000
    I don't think you can just send a print command to that printer... I think you have to have actual RIP software and even the newest graphtec cutters will not work with Corel X6 with Cutting Master
  21. I started with a laserpoint- was a decent machine until I needed a cut strip which I ended up paying through the nose for when I finally broke down to buy one since USCutter has been out of stock on them for over a year now. I started saving for a graphtec and upgraded so I didn't have to go through the headache again.
  22. vinylmotivations
    Small Printer
    Visit Richard over at cobra inks.... http://www.cobraink.com/ Mine has been running strong over a year and a half, plus the bulk ink saves for tons of printing. Works great for general office use as well.
  23. vinylmotivations
    Cute Window Sticker
    Thanks!
  24. vinylmotivations
    canvas?
    All you can do is test it... not all materials are created equal. Depends if the canvas is treated or plain, teflon etc... I would just try a piece...
  25. vinylmotivations
    bad storm
    We have been very fortunate in the Des Moines area... Central Iowa for the folks that aren't from around here. We has a very unusually WARM winter though so go figure were having a typical 100+ degree humid Iowa summer like I remember as a kid.
