dbtoutfit
Digital Printed Vinyl Graphics. (using home desktop printer)
I've been researching this for a while, read the entire thread.
I plan on doing small runs of relatively small stickers 2"x2" to letter size at max.
-I'm thinking of going the Epson WF route, seems fairly cost effective.
-I'll probably use Frogjuice, since I'm horrible with application
What I don't see anywhere here is a cost analysis. I know it is difficult because each sticker has a different balance of each color, but I'd like to see something like.... THE epson wf30, printing full page rainbows(equal amounts of all colors) comes out to xxcents per letter sized sheet.
I swear I've seen this kind of breakdown before on consumer photo printers. Any thoughts?
Looking at the waterproof permanent white vinyl at papilio, at qty of 100 (8.5x11) it is 72 cents per sheet
combine that with this review of the epson workforce c40... which states 19.3 cents per page full color (down to 15.6 with the high yield cartridge)
"Unfortunately, the WorkForce 40's ink costs  are high. At the time of our review, the $17, standard-size black cartridge lasted 230 pages, or an outrageous 7.4 cents per page. Each color (cyan, magenta, yellow) cost $12.34 and lasted 310 pages, or nearly 4 cents per page--making a four-color page cost 19.3 cents."
that leaves us with 91.3 cents per full color page of vinyl (72+19.3). Sound about right? Add UV coating to that as well I guess.
go to cobraink.com get his refillable carts, or better yet buy a wf1100 from him with the cis already installed and your ink cost will be much much less.
@boosted,
  Thanks! I might buy one from them just to avoid having to get all the stuff.
Anyone else back up this company?
I got the WF 1100 2 weeks ago and printing beautifully!!!!recommend big time. :huh: ???
Guest debogus
The 1100 is on sale at office depot  for 129 until this saturday .Also at staples next week  ,starting sunday, for the same price
Guest debogus
"this picture was print on oracal 631m-010 vinyl using epson printer"
Pictures not posting .
So your printing on matte white oracal ? With Stock inks ?
What else is in your process ? Sealing method used ?
regular matte finish :Krylon Crystal Clear Acrylic Spray Gloss  :huh: ???
regular matte finish :Krylon Crystal Clear Acrylic Spray Gloss  :thumbsup: :thumbsup:
So one whom wanted to get into this would need what?
Epson 1100?
What kind of ink?
Do I need the CIS System?
What Vinyl is needed?
Can the printable adhesive inkjet vinyl be used to wrap the top of a laptop and if so would you have to use a laminate on it or would it be ok without it?
Thank you!!!!  :thumbsup:
Guest debogus
aguilar can you post more pictures?
Laminate is advised.
But try it first on your own laptop.
Paco
Been using a CIS wf30. Seems to work ok, but I'm still lusting after a solvent printer. Its really the texture of the papillo vinyl sheets that I don't like that much.
heres my noob question....can you print on any vinyl or is there certain vinyls just for printing decals? i have a 1100 and want to try this what will i need?
Only on coated vinyl to keep the ink from bleeding and smearing.
Paco
ANY SUGGESTIONS ON WHAT COATED VINYL TO USE AND WHERE TO GET IT? THANKS
I have had great luck with papilio waterproof vinyl and have been printing it with pigment ink from my cobra epson 1100 printer and then spraying them with Aerosol UV Laminate Spray 12 Oz .
http://texascraft.com/hps/
What cutter do you have?
