webcat 2 Posted September 10, 2021 {GRAPHTEC CE7000} So I'm working with a small roll of 15" by probably about 15ft. Thang has been rolled up for over a year, so I put it in under the wheels, lock them down, yet, it obviously rolls up by the cut head. I use my fingers to try to keep it down, as I hit 1 for Front Edge scan, which it does, I think....Only thing is, now when I go back to the software to send the design to the plotter, it's not shows at the front right edge like it normally does when I cut on sheets. So at first, I think it's not loading my design, but to my utter surprise, it "is" loading it, just 91 inches back in the roll for some reason??? And for some other reason, the positioning inputs are greyed out so I cant change them, Does anyone have any knowledge of this? I'm not sure what I could have done wrong, if it's on me... Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2021 you must push the ORIGIN button before sending design..That is where the cutter starts measuring your design. Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 is the origin button in the software? because I always put this thing, but that's after the design is actually showing up See attached Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 No, I bet you mean the actual origin button on the machine. lol. No, I didn't know I was suppose to put that. So how does it go, I click 1, for Roll Front Edge, let it do it's thing then I press "ORIGIN" Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2021 push the ORIGIN button on the vinyl cutter. That is the last thing you do before you send the cut. Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 Uuh....Mz Skeeter, is it ok....if I say..... I LOVE YOU That worked for me. Thank you alot lol Share this post Link to post Share on other sites
slice&dice 2,451 Posted September 11, 2021 For the record, Mz. Skeeter is loved by many here --- she is a true gem. 2 Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 I can see why @slice&dice I can see why. Thanks again @MZ SKEETER 2 Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 You know what, I better confirm, just so I know (knowledge is the key). Is the reason I had to hit origin, because I chose to do a Roll? Because I never hit it when I made my first Lettering cuts the other day? Also, am I suppose to be hitting the Poll button when I get to the Cut Page? I was doing that thinking it was what was making things work, ya know, Like I "had" to do it for the cut to work. Am I right about that much or no? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2021 I have a 30" FC. Owned since 2008. I have NEVER used poll in all of my years of cutting. I know how big my designs are and how large my vinyl is. Even scraps. Origin is your X Y measurement at 0/0 That is where your design is being measured from. That is the starting point of measuring your design. You should always push the ORIGIN button on your cutter, every time. I also turned off my media sensor and pinch roller sensor on day 1. I can put my blade very close to the vinyl edge. Share this post Link to post Share on other sites
webcat 2 Posted September 11, 2021 Awesome, thanks for this! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2021 I also do not change my material width/length for different rolls. My width stays at 29.6" w x 1968" L. I use 15", 24" 30" wide rolls. The only time I would change user defined, is if using a piece of scrap, and want to run some copies. Like a 6" wide scrap and want to use part of it.. I only buy 50 yard length rolls, but I keep scraps. Your welcome. Share this post Link to post Share on other sites
