kainth.c.s 48 Posted February 25, 2021 Hello everybody Can we print on the greaseproof paper (used to wrap Donuts, Breads, Pies etc.) using a normal Laser printer? Share this post Link to post Share on other sites
Dakotagrafx 7,279 Posted February 25, 2021 pretty sure it will melt (the coating that makes it grease proof) with the unit that heats the toner to cure it - but who knows - something I personally wouldn't try Share this post Link to post Share on other sites
kainth.c.s 48 Posted February 28, 2021 On 2/26/2021 at 7:17 AM, Dakotagrafx said: pretty sure it will melt (the coating that makes it grease proof) with the unit that heats the toner to cure it - but who knows - something I personally wouldn't try Thanks. So would a normal Ink printer do the trick? It is a one off job that we need to do,; however, the catch is that it is going into a bakery shop so I guess there might be issues with the ink in case it starts to come off. Any suggestions please? Share this post Link to post Share on other sites
Dakotagrafx 7,279 Posted February 28, 2021 1 minute ago, kainth.c.s said: Thanks. So would a normal Ink printer do the trick? It is a one off job that we need to do,; however, the catch is that it is going into a bakery shop so I guess there might be issues with the ink in case it starts to come off. Any suggestions please? Also you need food safe ink, betting they are normally offset printed. Personally if the liability outweighs the reward I pass. Trying to do every job that is not in your area of expertise is a sure way to get caught up in a bad situation. 1 Share this post Link to post Share on other sites
kainth.c.s 48 Posted February 28, 2021 1 minute ago, Dakotagrafx said: Also you need food safe ink, betting they are normally offset printed. Personally if the liability outweighs the reward I pass. Trying to do every job that is not in your area of expertise is a sure way to get caught up in a bad situation. Thanks pal. Will convey the message Share this post Link to post Share on other sites
Dakotagrafx 7,279 Posted February 28, 2021 I know our paper used to use soybean based ink - but unsure what is considered food safe Share this post Link to post Share on other sites
kainth.c.s 48 Posted February 28, 2021 1 hour ago, Dakotagrafx said: I know our paper used to use soybean based ink - but unsure what is considered food safe Even I am not 100% sure, but I guess the Ink that contains minimum amount of chemicals Share this post Link to post Share on other sites
