I purchased a new cut strip from US CUTTER, for my Titan 2. The adhesive is on the backing instead on the nylon cut strip. should I return or can I fix, I haven't removed all the backing. And there is no adhesive in the cut strip channel.
Put some double stick tape,  or carpet tape on it.   Some strips don't even have adhesive on them when they are sold.
Banner tape seems the stickiest.
It is sold by USCutter.
1 minute ago, GHEENEE1 said:
Would contact cement work? I have that.
personally the thing I think that would be harder with contact cement would be to get it absolutely even across the entire surface - - not sure why it wouldn't work but you don't want any areas thicker than others that can effect your cuts
