holly.green8714
Opening Scal 5 svg in Scal 4 program
I don't have SCALP but maybe check in your export or save-as options and see if you can save it in an older format. Sometimes you have to import newer format files in a different way such as drag and drop or use the Import command rather than trying to just open it up.
SVG is an open format and as a result not every program implements all the protocols exactly the same way. Most usually have an option to save as a "flat" svg file, which from my understanding is the bare basics of an SVG file. It does support some of the "fancier" features that SVG can do.
