ericlecarde 1 Posted September 30, 2017 I was wondering if the spacing between decals can be reduced.There is at least a 3/4 space between the cuts and its wasting my vinyl a lot. Anyone know how to change this? Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 23, 2018 Contact Vinyl Master support. It is a rebranded software from Vinyl Master. Share this post Link to post Share on other sites
ShaneGreen 131 Posted May 23, 2018 Under "Tools" there is a "Weedbox Offset" that controls how big the weedbox is around an image. I forget what the default is, but I changed mine to 0.05in. I could swear there is a setting for how much room it leaves between them if you are cutting multiples, but I can't find the setting. In the cut spooler you can click "settings" and "tight packing" and that will reduce the space between multiple images....but only for this cut. You'll have to reset it each time you go to cut something. Share this post Link to post Share on other sites
