Robert2495 1 Posted September 27, 2017 I have a graphtec ce 6000 (2ft) plotter, and whenever i do a long sheet(vinyl) cutting and when the cutting process reached the end of the vinyl the vinyl sqeezed in the center between the pinch roller making the viny bulge in the center.. because of this reason i get an error in contour cutting. how can i solve this Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 27, 2017 post some screen shots of your vinyl setup in the cutter, so we can see where you have the pinch rollers.etc. Post a picture of your problem.. I have cut for years, and my vinyl has not squeezed /bulged,up in the center. ever. Try slowing the cutter down if your cutting fast. How did you set your blade depth? You should just barely see or feel the blade tip out of the blade holder. 1 Share this post Link to post Share on other sites
Robert2495 1 Posted October 12, 2017 HERE ARE THE PICS. ALSO, WHEN IT SCAN THE REGISTRATION MARK THE DISPLAY SHOWS 'OFF SCALE' AND CUT SLIGHTLY OFF THE PRINT EVEN THOUGH IT DETECTS THE REGISTRATION MARK Share this post Link to post Share on other sites
