KyleS
CE 6000-60 When cutting is changing the cutter setting on its own
This issue recently started. Whenever we start a cut, say on setting 5, it will cut the first object on the print on that setting, but once it jumps to the next one it will switch to setting 1 on its own.
Has anyone had this issue and have a idea on how to fix it?
Thanks for any and all help!
  Never heard of that.  I never run from the settings on the cutter,  I run every order from the Graphtec Cutting Controller using condition 9.    Never had a problem.  Easy to control everything from your computer.  You might not like it.  but I always have.  Mine is an older FC...
If you don't like that idea,  Factory reset the cutter. see if that changes anything. That's all I can think of.
if using a cutting program like flexi it has the ability in that program to change the settings on each job . . . . no idea what program you are using so no idea if that is it or not. also if you have the graphtec cut controller downloaded on your computer it can change it from the computer too
im using Cutting master for the processing of it. ill look to see if i changed any settings there
