Anetski 2 Posted March 24, 2017 HI I am using a Graphtec Ce6000 cutter and I cut the Aqueous version of Photo Tex. I have absolutely no problems in cutting squares but everytime I cut circles or anything else but a square angles it leaves a tiny piece not cut through. It is the spot where it starts cutting and where it finishes that is left unfinished. It drives me bunkers. I have the special needle required (CB15UA) and I have slowed down the speed to 10 and also played around with the force and the Offset and nothing works. Help please. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 24, 2017 Found this, PhotoTexGroup Newbie Members 1 1 post Posted April 9, 2014 · Report post Hello, So we have 100's of printers that do nothing but process cutout on Photo Tex material all day - every day, but you need the right blade, slow the speed, overlap and has to be a sharp knife as yes this is a fabric. We own 2 Offline cutters a Roland GX-400/600 and so we know to use a 60 Degree Carbide blade. But you can always e-mail me and I can try to help walterjr@phototexgroup.com www.phototexgroup.com Walter Gierlach Jr. , President 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 24, 2017 Does your software have overcut? If so use it. 2 Share this post Link to post Share on other sites
mfatty500 454 Posted March 24, 2017 Are you changing the setting for use with the u15 blade? Share this post Link to post Share on other sites
Anetski 2 Posted March 26, 2017 On 3/24/2017 at 3:11 PM, MZ SKEETER said: Does your software have overcut? If so use it. I will try this right now. Share this post Link to post Share on other sites
Anetski 2 Posted March 26, 2017 On 3/25/2017 at 2:27 AM, mfatty500 said: Are you changing the setting for use with the u15 blade? yes Share this post Link to post Share on other sites
Anetski 2 Posted March 26, 2017 On 3/24/2017 at 3:04 PM, MZ SKEETER said: Found this, PhotoTexGroup Newbie Members 1 1 post Posted April 9, 2014 · Report post Hello, So we have 100's of printers that do nothing but process cutout on Photo Tex material all day - every day, but you need the right blade, slow the speed, overlap and has to be a sharp knife as yes this is a fabric. We own 2 Offline cutters a Roland GX-400/600 and so we know to use a 60 Degree Carbide blade. But you can always e-mail me and I can try to help walterjr@phototexgroup.com www.phototexgroup.com Walter Gierlach Jr. , President Thanks Share this post Link to post Share on other sites
