DNA_Vinyl 262 Posted July 1, 2016 My buddy wants to wrap his tank. I've never done this before so. Would 751 be the right stuff? Little heat little stretching and should be ok....right? *nervous* Share this post Link to post Share on other sites
Command 97 Posted July 1, 2016 Get some wrap vinyl like Oracal 970 or Hexis HX 20000. Wrapping a tank can be challenging even with wrap vinyl because it is nothing but complex curves. 751 Is not going to work on a tank. It is possible to wrap *something* with 751 as a "poor mans" wrap, but its totally the wrong material and only good for flat surfaces. Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 1, 2016 Ahhh....great. They don't make 970 for my little cutter. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted July 1, 2016 Ahhh....great. They don't make 970 for my little cutter. if you are going to "wrap" it you won't be cutting it till you trim after applying - Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 1, 2016 If there's a picture I can't see it from my work. Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 1, 2016 Good point though Dakota. Share this post Link to post Share on other sites
hhsg 43 Posted July 2, 2016 Did a tank like that extra pair of hands are great Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 5, 2016 I should be more clear...it's not a "wrap" per say...but flames. So it's not the entire thing. So 751 should be ok from what I read. ya? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 5, 2016 I would still step it up to 951 were it me. Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 6, 2016 When using said vinyl...do you use transfer tape? I guess it depends on what your doing. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 6, 2016 With cut vinyl you'll need transfer tape and that is where the compound curves will get tricky. Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted July 7, 2016 Unless I install it wet. That shouldn't be a problem. I hope. Share this post Link to post Share on other sites
