LFleshman
US Cutter MH Carriage Arm broke
I have been working with my vinyl cutter for about a month now.  About a week ago the arm that holds the blade cartridge into place broke in half, so I ordered a new one.  I double checked that this was the correct part and that the arm shown in the picture was the exact same.  I received the new arm today, and it is not the same!  Anyone had any issues with this happening to them?  After it broke on me I realized that I had my blade way too low.  Any thoughts and suggestions would be helpful!
There are 2 different arms for the MH.
The Old style has 2 places to put a holder.  One in front of the other.
The newer style arm only has one.  You have to make sure you order the correct style based on your cutter.
and when you get the carriage arm fixed,  this is how to set your blade depth
