jaytee425 0 Posted March 24, 2012 i got this cutter like 2 months ago worked good. Now it will cut then will freak out and cuts up the text. i did the ground wire thing and i have the stand on wood and the wires are off the floor. can any one help ?? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 24, 2012 get a serial cable or keyspan adapter. Read how much it helps Share this post Link to post Share on other sites
jaytee425 0 Posted March 24, 2012 i have a keyspan from uscutter Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 24, 2012 are you sure it's not the image your trying to cut? Does it have stray nodes? If you think it's static, try wiping some dryer sheets on the vinyl. Share this post Link to post Share on other sites
jaytee425 0 Posted March 24, 2012 it maybe nodes i have tryed the dryer sheet thing it just made it smell good lol Share this post Link to post Share on other sites
MrMopar64 47 Posted March 24, 2012 Try oping the image in wire frame and see if there is any extra lines Good Luck MM64 Share this post Link to post Share on other sites
stetson5331 80 Posted March 25, 2012 KISS method to determin if it's your artwork or the machine...Does it do it to all artwork or just this one? If all do the keyspan people say it's the fix all for all..If it's this one piece do what the others told you..check for stray nodes or paths.. good luck let us know what you find stetson5331 Share this post Link to post Share on other sites
jaytee425 0 Posted March 30, 2012 i did another image still cutting up the artwork the guy from the uscutter told me to get some kinda spray will that work Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 30, 2012 i did another image still cutting up the artwork the guy from the uscutter told me to get some kinda spray will that work probably anti static spray... couldn't hurt. Share this post Link to post Share on other sites
jaytee425 0 Posted March 31, 2012 OK wow does anyone have a MH721 and dont have any thing going wrong with it if so how do you have it set up. and i have a ioline classic is that a better cutter then 721 like should i get that one going or is that just to old what do you guys think Share this post Link to post Share on other sites
Rodger 527 Posted March 31, 2012 PLENTY of MH721 working flawless . Get them both going Share this post Link to post Share on other sites
jaytee425 0 Posted March 31, 2012 ok the spray didnt do anything what is it i need to do here ? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 31, 2012 ok the spray didnt do anything what is it i need to do here ? does it do it with everything you cut? or just that image? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 1, 2012 every thing Have you rechecked your settings? Something sounds wrong. start here and go thru it again.. Reinstall your cutting software. See if that helps. http://start.uscutter.com/ Share this post Link to post Share on other sites
jaytee425 0 Posted April 3, 2012 i got it to work set the baud to 4800 the put the cutter to copam and it work good Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 3, 2012 i got it to work set the baud to 4800 the put the cutter to copam and it work good great, glad you got it. Share this post Link to post Share on other sites
