Actualgrafix 0 Posted June 21, 2007 I bought a 4050 about a month ago and i cant figure out how to cut cinyl with pieces less than 6"? Is this even possible? Also, does anyone know what driver works best for the 4050 in flexi? Thanx guys. Share this post Link to post Share on other sites
Actualgrafix 0 Posted July 17, 2007 does no one have the 4050 in this forum? Share this post Link to post Share on other sites
kenimes 42 Posted July 17, 2007 We have only sold about a dozen 4050's so far. Which driver are you using in Flexi? Share this post Link to post Share on other sites
Actualgrafix 0 Posted July 18, 2007 i am using the PNC 1000 driver Ken. It seems to run very well with it. No problems yet. Share this post Link to post Share on other sites
Actualgrafix 0 Posted July 18, 2007 is it possible to cut less than 6" with this plotter? I have a 5" piece of vinyl about 20 foot long that i would like to cut but i cant figure out houw to get the pinch rollers to go less than 6". Share this post Link to post Share on other sites
kenimes 42 Posted July 18, 2007 You can use the 2 green sections on thr right side of the cutter for 5" material. To do so you will need to remove the little screw on the back with a rubber bushing, that will allow you to place the second pinch roller in the green. Share this post Link to post Share on other sites
Rodger 527 Posted August 11, 2007 i have a 2500 . where do you put the vinyl's edge on the right side ? the manual's instructions dont make it simple enough for me . line it up where the knife sets before starting edge of 1rst pinch roller ? thanks , rodger myers Share this post Link to post Share on other sites
kenimes 42 Posted August 13, 2007 I usually load it about an inch or two off the right side, but it really depends on where you WANT it loaded using the pinch rollers in the green sections. Share this post Link to post Share on other sites
