new2this 1 Posted October 15, 2008 As far as i can tell this is a 3 color image. after much time its cleaned up and ready to cut. why does it show 8 colors in my production manager? as you can see the first cut should be black, then ill lay the orange in 2 places then the reddish. although the orange layer should only have the lower swoosh and the small box above the cross. Have i done something wrong? ive uploaded it in eps and jpg if you wouldnt mind taking a look. thanks merles ready to cut.eps merles ready to cut.eps Share this post Link to post Share on other sites
darkdan 3 Posted October 15, 2008 Just cut the colors you need and sort it out in the weeding process. But if you really want to fix it, turns out the parts plus logo has several colors stacked on top of each other. If you order them (send to back) and then delete it you'll remove them. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 15, 2008 How did you vectorize that? If it was Inkscape, adjust the number of passes down some. If you vectorized in Flexi,adjust the number of posturized colors. Share this post Link to post Share on other sites
