Photovor 0 Posted August 29, 2008 I actually have the refine 12" cutter. I'm very happy with it, especially with the precision of the smaller lettering. The last company I worked for had an Ioline 60" cuter, but any lettering under 1/2" high was marginal. Since the stuff I'm doing now is smaller decals and stencils, this is great. I'm actually at work now, and the cutter is at home, but can someone measure the maximum width of material it can take please? Can I fit a 15" roll through there (even though it can only cut 10.75" of that? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 29, 2008 I'm not sure I understand what you want. If you have the cutter,measure it. A 15" roll is 15". Share this post Link to post Share on other sites
Photovor 0 Posted August 30, 2008 Just got home to measure. The opening on the cutter appears to be 14.25" wide, so I wouldn't be able to fit a 15" roll of vinyl through there. Share this post Link to post Share on other sites
kenimes 42 Posted September 4, 2008 I think it will Feed about 14" width, but actual cutting width is about 11 1/2" Share this post Link to post Share on other sites
