Benr98 40 Posted August 27, 2008 I have a small order to do name tags, anyone done them using vinyl? Thanks Share this post Link to post Share on other sites
FatDad 2 Posted August 27, 2008 depending on the size is what counts Share this post Link to post Share on other sites
Benr98 40 Posted August 27, 2008 So you have done some Fatdad? If so where did you get your name tags? We have done some before but we used dye sublimation...I want to try vinyl this time. Jenny Share this post Link to post Share on other sites
FatDad 2 Posted August 27, 2008 So you have done some Fatdad? If so where did you get your name tags? We have done some before but we used dye sublimation...I want to try vinyl this time. Jenny i TRIED to do a few and i ended up using a label maker. the were way too small and it was one of the first things i tried doing. Share this post Link to post Share on other sites
Benr98 40 Posted August 27, 2008 Ok...well I'll see what I can do...if they turn out decent I'll post them! I found some blanks I had originally for dye sub....I think it's going to work out nicely..might just need to put a clear cover over the top to keep the vinyl from peeling...but would work perfectly for those small companies that change employees more often! Jenny Share this post Link to post Share on other sites
Graphic Systems 1 Posted August 28, 2008 Kroy signs is a great place for the odd job! They have name tags there Share this post Link to post Share on other sites
Benr98 40 Posted August 28, 2008 thanks I'll check them out!!! Share this post Link to post Share on other sites
