ky1duck 0 Posted May 23, 2007 i use coral x3 layed out a simple checkerboard pattern, .5 x .5 inch that was 3"wide and 8"long but after sending it to signcut-x2 and telling it to cut the squars cut at about 10" x 10". any idea what i did wrong or is there a problem with signcut using the same size as coral x3. thx for your time. duck Share this post Link to post Share on other sites
ky1duck 0 Posted May 23, 2007 just tried using text and had the same problem, did a name that was 3.5 tall and 8.5 wide, but after sending to signcut and telling it to cut, it cut the name at about 9hi x 24wide. all numbers are in inches thx Share this post Link to post Share on other sites
comanswoodwork 0 Posted May 23, 2007 You must have a setting messed up somewhere. I just typed some text into corel x3 and sent it to sgncut and it remained the same size without any problem. Check the image size at the top left in signcut after you send it. It should match the image size indicated in corel at the top left also. Check to be sure that both programs are set to inches also. Good luck. Share this post Link to post Share on other sites
ky1duck 0 Posted May 23, 2007 thanks guys, i got worked out, put in wrong numbers in the calabration screen. thx. Share this post Link to post Share on other sites
