Paintslinger 0 Posted May 11, 2007 When I import clipart from inscape to signcut it wants to cut the objects 2 times. When I cut it strait from signcut it cut it 1 time like it should.Or when I down load the clipart to add text to it in inkscape then send it back to signcut it cuts the clipart 2 times and the text only 1 time .When it cuts it twice it cuts the paper underneath the vinyl. What do I have set wrongs. Thanks alot Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 11, 2007 When it cuts twice,I think that there are 2 layers there,I've had this happen.When you go to cut ,check on the colors bar,see if there are more than one layer. Share this post Link to post Share on other sites
