Jerry775 0 Posted August 5, 2008 I bought a USCUTTER LaserPoint 24" I set the cutter properly so it just goes through the vinyl only. I print the test page that says "WELCOME TO SIGN BLAZER ELEMENTS CUT TEST FILE IF YOU HAVE LOADED VINYL INTO YOUR CUTTER; YOU CAN CUT THIS TEXT BY PRESSING CUTTER, THEN PRESS CUT, THE PRESS CUT TILE. OK I cut this and when I go to peal off the stuff you don't want it peels up letters I cannot get them to stay on the backing paper. I tried press (cutting pressure) all the way up to 135 and I cannot get it to not peel up the letters most all of them stay on the backing paper but some peel up even when I go slow and try to get them to stay down I have no luck. I loose about 6 letters every time. I tried running the repeat up to .005 default is .001. :-What is the problem here? Share this post Link to post Share on other sites
RegisG 0 Posted August 5, 2008 It would be good to watch some of the weeding videos. If you have not done this before, it takes some practice. Best of luck. Share this post Link to post Share on other sites
Jerry775 0 Posted August 5, 2008 where do I go for the weeding video's? Share this post Link to post Share on other sites
RegisG 0 Posted August 5, 2008 where do I go for the weeding video's? There are a couple in this link http://forum.uscutter.com/index.php/topic,2413.0.html And then do a search Share this post Link to post Share on other sites
haumana 1,220 Posted August 8, 2008 you might need to have you blade stick out just a hairline more. your vinyl might also be old, or the adhesive really, really sticky. i noticed on some vinyls, the adhesive is so sticky that it is a bit more difficult when weeding. Share this post Link to post Share on other sites
