Kysmiley 0 Posted July 20, 2008 It seems that when i cut a design if there is a slightest off tracking the lettering or design may go outside the box just a little bit and get cut off. How do I stop the cutter from cutting a box around my design. I am thinking this may help with my problem. Pat Share this post Link to post Share on other sites
Meregator 0 Posted July 20, 2008 In Sign Blazer, when you are on the cutter screen there should be a grey window to the left of the image of what you're going to cut. There are a bunch of boxes that you can check for different options - you want to uncheck all of the boxes for weeding (weed all, weed each copy, easy weed). That should stop it from cutting around your image. Meredith Share this post Link to post Share on other sites
