edge 67 Posted April 26, 2007 Projects sent from Corel to Signcut appear 90 degrees out of sync. Rather than the cut spooling from the top or bottom of my Corel screen, it cuts from right to left which forces me to rotate text and images 90 degrees counterclockwise, if I desire the print field to run from edge to edge of the vinyl rather than the length of the roll. I've tried changing the page layout in Corel from portrait to landscape with no effect on this problem. Am I overlooking a simple solution to this? I don't quite understand the 90/0 degree cut option in the CP2500 cutter settings, would a change here correct this problem? Share this post Link to post Share on other sites
Tazman00 0 Posted May 1, 2007 click the rotate tool in sign cut (red arrow on the left hand side) then at the bottom of the page click 90 degree arrow. that should solve your problem. Taz Share this post Link to post Share on other sites
