xhydro 0 Posted June 14, 2008 I don't even know what a bitmap image is, but I have one that I would like to use to cut some vinyl. The cutter does not like the idea, what do I need to do, to make the cutter happy? I'm using SBE Tom Share this post Link to post Share on other sites
haumana 1,220 Posted June 15, 2008 I don't even know what a bitmap image is, but I have one that I would like to use to cut some vinyl. The cutter does not like the idea, what do I need to do, to make the cutter happy? I'm using SBE Tom What kind of image are you looking for in particular? There are two kinds of images: raster and vector. Vector is the type that the cutters require. Tell us what graphic you're looking for, and someone should be able to post a vector version of it here for your to download and cut - provided that it's not a difficult request. Share this post Link to post Share on other sites
xhydro 0 Posted August 13, 2008 Hi all, As you can see I've been away for awhile. What I'm looking for is a Bada Bing sign with the girl on it. Thanks Tom Share this post Link to post Share on other sites
Guest kenya Posted August 13, 2008 Hi all, As you can see I've been away for awhile. What I'm looking for is a Bada Bing sign with the girl on it. Thanks Tom This one? bada-bing-close.eps bada-bing-close.eps Share this post Link to post Share on other sites
xhydro 0 Posted August 14, 2008 Kenya That's the one. Thank you, I'll be able to give it a try in a couple of hours. Thanks again, Tom Share this post Link to post Share on other sites
Benr98 40 Posted August 14, 2008 It looks like he only has one leg? Or did I do something wrong? Share this post Link to post Share on other sites
