mpanek 2 Posted February 9, 2024 I've been having very frustrating cut depth issues with my Titan 2 I use for personal work at home. I've spent a lot of time calibrating and replacing parts, but its like it's impossible to find the happy medium... I use a graphtec at my job, and the blade holder uses a spring loaded blade so there's less calibration for depth. You more just need to adjust the pressure. Has anyone done or have any insights on retrofitting a spring loaded blade holder on a titan or cutter that has a fixed blade? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted February 9, 2024 Your blade depth shouldn't just change. Have you looked at your cutting strip and made sure no scratches and gouges? This is the way to set your blade depth correctly. Posted hundreds of times on this forum. It works. No using a credit card or post it notes. That is way too much blade extended out of the blade holder. Use the TEST feature on your vinyl cutter. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should barely see and feel the blade tip out of the blade holder. Regular sign vinyl is only 2-3 mil thick. You only cut with the very tip of the blade. When you think the blade is so far in the blade holder, that you think it would not even cut, that is probably correct. Share this post Link to post Share on other sites
darcshadow 1,641 Posted February 11, 2024 The function of the spring and the adjustment of depth have nothing to do with each other. Set the blade depth per Mz Skeeters instructions. Then if you're still having issues look at things on the cutter, bad cutting strip, non smooth movements of the cutter head, correctly functional solenoid. With the blade set correctly it is impossible to cut too deep. 2 Share this post Link to post Share on other sites
