jfought 120 Posted May 29, 2008 my registration mrk button is missing. i am using SBE any ideas? Share this post Link to post Share on other sites
firemalt 10 Posted May 29, 2008 I don't think Elements has that option... But they are easy to make on your own... takes about 20 seconds. Share this post Link to post Share on other sites
Guest gracewriter Posted May 29, 2008 Signblazer elements doesn't have that option you have to do it manually by makeing squares and punch through. Share this post Link to post Share on other sites
jfought 120 Posted May 30, 2008 what do you mean punch through? Share this post Link to post Share on other sites
Guest gracewriter Posted May 30, 2008 To make a punch through, click the "square" box on the menu bar. Then make two squares where you want the registration marks. Then click the select button, then click edit, then select all, then arrange, weld, punch through. If you first don't click the select button then, edit, then select all, which I know sounds redundant, it won't work. That way you have just punched through all the layers and now have registration marks. Capiche? Share this post Link to post Share on other sites
Buggie Pilot 4 Posted May 31, 2008 I just make the circles in a third color and cut that color each time with each layer Share this post Link to post Share on other sites
