thebuigarian 1 Posted December 8, 2020 I am a bit confused by this, I have the Roland GX-24 and am using CutStudio to try and do some contour cutting. The issue is that after the cutter has found and scanned all 3 contour points, it just decides not to cut anything, with no error message or anything. I am unsure of what I am doing wrong and would love some help. I have attached a video for reference. Thank you! IMG_0296.MOV Share this post Link to post Share on other sites
Dakotagrafx 7,292 Posted December 8, 2020 did you add the contour lines to your artwork - must be vector contour lines . . . . Share this post Link to post Share on other sites
thebuigarian 1 Posted December 9, 2020 17 hours ago, Dakotagrafx said: did you add the contour lines to your artwork - must be vector contour lines . . . . Yes I did, at least through the CutStudio "Extract Contour Lines", even in the print preview I can see the lines. Share this post Link to post Share on other sites
Dakotagrafx 7,292 Posted December 9, 2020 2 hours ago, thebuigarian said: Yes I did, at least through the CutStudio "Extract Contour Lines", even in the print preview I can see the lines. I haven't used cut studio - I made my contour lines in flexi so really unsure of your particular process - Share this post Link to post Share on other sites
