13subie 0 Posted June 4, 2020 OK had the cutter for a few years. Moved and PC's "improve". Hooked up the cutter to a new PC window 10 64 bit. trial versions of software worked fine over USB. Purchased the full version and it worked for a few days. It didn't even notice the cutter as being there. Picked up the serial to USB adapter and after some trial and error have managed to get it to at least say its cutting. But, it does nothing. I unplug the cable and then it will start to moving the progress bar. But, doesn't cut. Am I missing something simple? TIA Dean Share this post Link to post Share on other sites
darcshadow 1,627 Posted June 4, 2020 The USB adapter emulates a comm port, which comm port is it set to? Make sure you have your cutting program set to the correct comm port. Also make sure the baud rate is 9600. Which adapter did you get? They are not all created equal and they don't all work. The Tripp lite one is what everyone on here recommends as it is well proven. 1 Share this post Link to post Share on other sites
13subie 0 Posted June 4, 2020 Yeah I checked the com port at 4 and baud rate 9600. The program is as well. I have the insignia adapter. Ill look for the Tripp lite one. Crazy thing is it worked fine up until a few days ago with the USB. No idea what may have changed. Thanks Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 4, 2020 What happens when you use SignBlazer and Com 2 -- change it from port 4 to 2 manually in the windows Device Manager. Also, you'll probably need the driver for the USB emulation. Share this post Link to post Share on other sites
13subie 0 Posted June 4, 2020 I just reinstalled the USB emulation. getting ready to try it now. Thanks Share this post Link to post Share on other sites
13subie 0 Posted June 4, 2020 It goes to cutting... doesnt freeze but doesnt cut either. Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 5, 2020 You are not really helping us troubleshoot. SignBlazer (choose RedSail in cutter setup) ? Com 2 ? Reboot computer ? 1 Share this post Link to post Share on other sites
darcshadow 1,627 Posted June 8, 2020 Does the test function on the cutter work? Long shot but the cutter itself might have died. Share this post Link to post Share on other sites
13subie 0 Posted June 19, 2020 I just got a new Tripp lite. I can now use the test function in the Sure cuts alot program and it makes the carriage go up and down. But, when I start to cut something the carriage moves slowly to the left of the machine. The vinyl rollers roll out the entire roll. Then the carriage stays at the far left. Any Ideas on that one? Ive been searching for an answer for this for over a week. Thanks I appreciate wll the help!!! Share this post Link to post Share on other sites
13subie 0 Posted June 19, 2020 Im on Com3 Im using sure cuts alot4 full copy. And I reboot after every driver install. Share this post Link to post Share on other sites
darcshadow 1,627 Posted June 22, 2020 Does the test function on the cutter itself work? Share this post Link to post Share on other sites
