tjracing 0 Posted May 13, 2008 Can someone help me I need this to be Vectorizing. Maybe only have it in 3 colors. Thank You Share this post Link to post Share on other sites
HawgDawg 0 Posted May 13, 2008 Here you go It needs some clean Up Dawg wickedlogoBW.eps wickedlogoBW.eps Share this post Link to post Share on other sites
HawgDawg 0 Posted May 13, 2008 With Color Dawg wickedlogo.eps wickedlogo.eps Share this post Link to post Share on other sites
tjracing 0 Posted May 14, 2008 Here you go It needs some clean Up Dawg Thank You for doing this for me. I only have one problem the black & white eps file will not open when I down loaded it can you help me. Thanks Share this post Link to post Share on other sites
HawgDawg 0 Posted May 14, 2008 I can send it in other formats if you need. You should be able to import the file vs opening it Dawg Share this post Link to post Share on other sites
Vermonster 111 Posted May 27, 2008 I'm a little rusty but I figured I'd take a crack at it. With Somthing like this...personally, I would persue Tracing the flaming text, getting skulls as close as possible and using them (if customer is ok), find the scrolls and match the fonts. Some things are just not easily traceable. Not without some extensive work. There are some online trace folks that charge decent prices for the amount of work (under 20 bucks if I remember correctly) and will have it done within 24 - 48 hours usually. If someone gives me detailed work like that during the bidding process, I normally just factor in sending the artwork out if it's this involved. Save the time, headache, and let a pro do it for pennies on the dollar what it would cost you. Someone like http://vectordoctor.com/pricing.html Of course, if this is a paying customer, and you mention that you could save him some money if he can get a usable file, they have moved rather quickly to accomodate me in the past Usually if they had business cards done or something, they may have better usuable artwork...not always though... There's not alot that can't be easily traced if you know how to convert it to B/W and if you have Inkscape or Corel X3. For this, I did the following in case you want to learn how... 1. In Photoshop, converted to Grayscale 2. Used the Threshold Tool to get it set B/W and as even as possible 3. Auto Traced in Corel There are many ways to do this, but this is kinda how I did it...and didn't yeild much better results then Dawgs mycrackatit.eps mycrackatit.eps Share this post Link to post Share on other sites
