Blackjack2359 0 Posted April 21, 2017 Is there anyway to adjust where Vinylmaster Cut puts the registration marks? When I am making several layers and most of the layers are a lot smaller than the first original layer, the program puts the registration marks on the same location on all of the layers. This is a very large waste of vinyl when I have to cut multiple layers for one vinyl sticker. And if there is no way to adjust the registration marks, has anyone found a different way so I don't keep wasting vinyl? Thanks in advance! Quote Share this post Link to post Share on other sites
Guest VinylMaster Support Posted April 21, 2017 If you go into the "Objects" menu, and select "Place registration marks", it will add registration marks around the selected items. Then you can select each mark and move it to any position you like, to save vinyl. (Note: if you use these marks, you do not need to select the Registration mark feature in the Send to Cut screen) 1 Quote Share this post Link to post Share on other sites
Blackjack2359 0 Posted April 21, 2017 Ah ha! AWESOME, thank you very much. Quote Share this post Link to post Share on other sites
