CharlieArya 0 Posted November 28, 2016 Hello, I am having extreme problems registering a contour cut on Printable Glitter Heat Transfer Material on out Titan3 ARMS Plotter. It seems that the plotter will not recognize the printed registration marks possibly because of the reflective qualities of the material. It passes the registration marks up and starts looking along the edge of the material or refuses look go find them at all. Has anyone had this problem? I have found a work around but it involves a lengthy process of adhering white calendar vinyl onto the glitter material and then printing, then cutting. Too much time. Can anyone help? Thanks in advance. Charlie Share this post Link to post Share on other sites
Wildgoose 4,199 Posted November 28, 2016 I am sure you are correct that it is the reflective nature of things. I have read that Graphtec ARMS sometimes fight reading regular vinyl if it has been laminated. The workaround that those guys were talking about was a piece of tape over the top with a dot or some such mark that would let it catch the right spot. What brand of glitter is printable? Share this post Link to post Share on other sites
