cdesigns 0 Posted April 25, 2008 I was wondering if this is normal , the letters are 1/2" and the cut is always the same but the letters are not cut completedly, My old plotter was $20,000 54" Versacamm , I sold my business and I bought this plotter to keep the hobby, but it's this servo problem or aligment problem? I have tested different vinyls, new blades, and even using the PEN I get the same results on 1/2" letters. I'm using Flexi-sign to output the cuts. I tried the same art using Flexi-sign with a roland 24" plotter and it cut it perfectly. What can I do to fix it? Share this post Link to post Share on other sites
Guest fivestar Posted April 25, 2008 knife offset in production manager or the holder isn' completely on track. Share this post Link to post Share on other sites
kenimes 42 Posted April 25, 2008 If you do the Test cut fromt he cutter itself do you get the same results? If so, might be the carriage off the track or something loose, and if not, might be the offset setting in the Production manager. Share this post Link to post Share on other sites
cdesigns 0 Posted April 27, 2008 If you do the Test cut fromt he cutter itself do you get the same results? If so, might be the carriage off the track or something loose, and if not, might be the offset setting in the Production manager. Test cut works perfect , I will keep looking for the porblem Share this post Link to post Share on other sites
kenimes 42 Posted April 27, 2008 You can make adjustments to the offset setting in Setup Properties of your Production manager for Flexi. Share this post Link to post Share on other sites
KrunkuliticusIII 0 Posted April 30, 2008 i have the same issue but i use sign blazer, and it happends only when i have a important job that requires saving vinyl of course. Just wondering where i can find those settings for SB Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 30, 2008 In SB...click CUTTER then SETUP. Blade offset is there. Share this post Link to post Share on other sites
KrunkuliticusIII 0 Posted May 1, 2008 EXCELLENT! will check it as soon as i'm with my cutter, she's kinda jealous that i'll be with my girlfriend tonight though haha Share this post Link to post Share on other sites
