Xmom 0 Posted October 22, 2015 I purchased a file from an Etsy vendor. SB will not recognize the file and the vendor can't help since she isn't familiar with SignBlazer. Trying to do a project with some girls at church. Thanks, XMom Share this post Link to post Share on other sites
mb20music 760 Posted October 22, 2015 Look at the other thread you created... Share this post Link to post Share on other sites
slice&dice 2,451 Posted October 22, 2015 OK, Xmom, just follow these instructions --- download and install IRFANVIEW. It's free (including opensource Ghostscript). Your file (assume it's .eps) should open in that program. Then, select the graphic in the Irfanview window (CTRL+A) and copy (CTRL+C) and paste (CTRL+V) into Signblazer. Now, with the graphic selected in SB, go to the Image menu and choose Mode -- Monochrome. You'll get a grey graphic. With that selected, go back to the Image menu and choose Vectorise. The result of that will be a BLUE graphic. Get rid of the grey, keep the blue. If you need to, clean it up with node editing. That's it. Share this post Link to post Share on other sites
mark-s 1,126 Posted October 22, 2015 Here are a couple might need a bit of work. mark-s SALT LAKE TEMPLE.ai SALT LAKE TEMPLE B.ai Share this post Link to post Share on other sites
Xmom 0 Posted October 23, 2015 Thank you for your help! I appreciate it so much! Slice&dice, you make it sound so easy. XMom Share this post Link to post Share on other sites
