Athienou 0 Posted May 4, 2015 Hello, good morning,I have seen you are the expert when it comes to "Creation" vinyl cutter problem solving/solutions.I would really appreciate some advise, please. What has happened to mine is that I forgot to switch it off overnight and now it doesn`t start up.I took it`s cover off, checked it has power coming in, but won`t start.What could be the problem to it, please?Many thanks,Peter Share this post Link to post Share on other sites
fustratedinhawaii 71 Posted May 5, 2015 I don't have your machine, but if it just stopped working like that, 1st thing I would do is check if there is a fuse that blew out (either at your panel to your house, then the machine's fuse). Please let us know when you get it fixed, to help others ! Share this post Link to post Share on other sites
Athienou 0 Posted May 5, 2015 Hello I don't have your machine, but if it just stopped working like that, 1st thing I would do is check if there is a fuse that blew out (either at your panel to your house, then the machine's fuse).Please let us know when you get it fixed, to help others ! Thanks but I have checked the fuse and it also has power coming in. Have no clue what is wrong to it, but heard someone had the same issue a couple of years back, I just haven`t found any tred to the solution to this problem. Seems to be a common thing to these machines though. Thanks, keep waiting. Share this post Link to post Share on other sites
signyouup 178 Posted May 5, 2015 Check for voltage out of the power supply. the output will probably have more connections than the input and be DC.The link below has a picture. http://www.uscutter.com/Creation-PCUT-Power-Supply-for-24-Cutter Share this post Link to post Share on other sites
Moody Blue 505 Posted May 5, 2015 Dont have a solution to the problem but I also own a PCUT. Subscribed just in case I run into this problem lol. Hope you get your issue fixed. Share this post Link to post Share on other sites
