Greenham 3 Posted January 21, 2015 I did a search and didn't see anything to help me with the needed settings for cutting metallic vinyl. Material: http://www.ebay.com/itm/130484286803 Issues: My test cut had the material slipping between the pinch roller and driver roller The test also showed the knife not completely cutting through the metallic material. My thoughts: Increase pinch roller pressure Slow cutter speed down Increase cutter head pressure Question: Does anyone have any guidance on these settings to get through this material? Any tips,tricks or hints on increasing pinch roller "grip" besides just increasing pressure? All help, thoughts, comments welcome. As always thank you Mike T Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 21, 2015 First 2 things to check is make sure you're blade tip isn't broken or dull. Second is are you pulling slack off the roll so the cutter isn't trying to pull on the whole roll? 1 Share this post Link to post Share on other sites
Kcross47601 13 Posted January 21, 2015 First 2 things to check is make sure you're blade tip isn't broken or dull. Second is are you pulling slack off the roll so the cutter isn't trying to pull on the whole roll? +1 on what Dakota said. On my MH721, I didn't notice much difference in the downforce when I cut matallics but it's also hard for that machine to cut it cleanly. I would increase the pinch toller pressure and pre pull off the amount of material you need so it's not dragging off the roll. I also use to use 60 degree blades to help cut cleanly. It's tougher material just like a thicker vinyl would be with it being 3 mil and a 45 will not last long and start to mess up quick. I did the came thing cutting reflective vinyl. Kris 1 Share this post Link to post Share on other sites
mb20music 760 Posted January 21, 2015 You might want to try a little more blade. 1 Share this post Link to post Share on other sites
Greenham 3 Posted January 22, 2015 Thanki you for all the input. Fortunatly I won't be cutting this stuff very often. After adding a bit more pressure on the pinch rollers and taking your advice to pre-roll the material I was able to cut though the stuff resasonably well. Thank you again for your help 2 Share this post Link to post Share on other sites
