jgr1269 0 Posted April 11, 2008 When cutting multiple copies or multi lines of words the cutter goes back and cuts through part of the previous word. Almost like the vinyl isn't advancing far enough. Any help? I've wasted alot of vinyl. Share this post Link to post Share on other sites
kenimes 42 Posted April 11, 2008 Which cutting program? Share this post Link to post Share on other sites
jgr1269 0 Posted April 11, 2008 Signblazer Elements. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 11, 2008 I have no idea if this applies to your particular cutter, but in Signblazer you can adjust the space between cuts,amount of advance,etc..in the settings. Share this post Link to post Share on other sites
kenimes 42 Posted April 11, 2008 My first thoguht would be a setting in the software. Have you changed any of the settings recently? Share this post Link to post Share on other sites
jgr1269 0 Posted April 11, 2008 I just set it up a couple days ago. The problem just popped up yesterday. I don't know a whole lot about changes in the software so I'm not sure if it's something I have done. The problem started when I was trying to cut multiple copies. Share this post Link to post Share on other sites
jgr1269 0 Posted April 11, 2008 My settings are set at .25 or 1/4". I had problems cutting a 3 line business name. The top line was distorted with an arc and the following 2 lines were straight, but the cutter would go up into the arced area when cutting the second line. I have changed the cutter for best tracking and it seems to have solved the problem. Thanks for your replies. Share this post Link to post Share on other sites
kenimes 42 Posted April 14, 2008 Glad to hear you found a resolution, and thank you for posting what seems to have helped. Share this post Link to post Share on other sites
