sashatronics
Copam-3500 makes weird cut at the end? pICS inside
well, yesterday it looked perfect for all the scetches i did, exept the last one..anyways here is the problem, you see on the pics, when ether it ends cut/scetch it makes this line??? it does mostly times when it ends, but it does same when i tell it to do weed square around it.. i am usinfg mac OSX , thru usb to 9 pin the one copam came with. Is that the problem, should i get another Keypan??? or i do something wrong? it does same on all scetches i did today..
i use  10 cm and 50g  and 0...
width=800 height=600http://i169.photobucket.com/albums/u208/sashatronics/DSC01076.jpg[/img]
I don't run a mac,but I have seen a lot of posts where they had problems with the usb adapter supplied with the cutter.And when they went to the keyspan adapter it solved the majority of the problems.
its official KEYSPAN USA-19HS rulles!!!!!
you guys at us cutter should now include to all your buyers keyspan , or at least let em know about issue with usb port. just paid $40 bucks for the thing, and in first place its copam problem.. think about that..
i use mac G5 , OSX.. work like it should now..perfect..so happy.. ;D
