Mo710 1 Posted June 27, 2014 I have a titan 2 and need to know which product I need to get to cut out designs on the titan, and then apply to stones to sandblast. Anyone help me out? Thanks in advance 1 Share this post Link to post Share on other sites
Neuromax 97 Posted June 27, 2014 I have done them using 651 with no problem. The trick is to heat the rock slightly with a torch, blow drier, heat gun etc. Not to get it hot, just warm then apply the 651. A lot of times its easier to put it on as a solid sheet then weed it on the rock (or glass or whatever you are blasting) 1 Share this post Link to post Share on other sites
Mo710 1 Posted June 27, 2014 You use AO on the vinyl and it holds up? How intricate can you be? Share this post Link to post Share on other sites
rlvied 292 Posted June 27, 2014 Mo I have etched several stones with ao and used paint mask as the resist. The one with the heart is about 1 1/2 X 2 inches and the rose was 2 x 3 inches. Bob 1 Share this post Link to post Share on other sites
Mo710 1 Posted June 28, 2014 Those are beautiful!! Thanks for sharing. You use the 811 or 813 paint mask? Share this post Link to post Share on other sites
rlvied 292 Posted June 28, 2014 I use Avery paint mask. It comes in 2 different types, standard and high temp. I use the standard type Share this post Link to post Share on other sites
