Rip_frannie 47 Posted May 1, 2014 So I have a fj-600. I took the main station apart to clean the dampeners and the heads. I put it back together and tried to do a test print. Now no matter what. All I get is a temp too low message. I've tried unplugging it for a day or so. I also tried having the main power on and secondary off for a few hours. Anyone else have this problem or know how to fix it ? Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 Did you have the main power off when doing the maint? Never. Heard o's cleaning damper, they are a normal disposable item. How did you clean the heads? Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 I used the swabs with the cleaning solution. Moved it to the side and just dabbed around it. Yeah I had the main power off Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 My best guess is a head cable not on right or bad head. Either way make sure the main power is off before touching it the main board is about 2,000 when you can find one if you blow that. Otherwise head is about 850 Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 Also the fj600 is one of the units listed as not able to convert to solvent ink so stay with the pigment, it will eat the heart out of it otherwise Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 Yeah I inpluged it completely. I put the cable in like 3 times. Same message. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 Next step a head I would guess Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 Yeah I planned on the head. But it was fine before. So I don't know Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 Do you know if on the head. The blue part of the ribbon is up or down ? I have it up Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 Figured it outlet Dakota. Cable was upside down. Blue side goes down 1 Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 lucky you didn't fry the head board - glad you got it figured out Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 1, 2014 Are you able to refill these cartridges ? Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 I am not familiar with the pigment inks for that printer but am sure someone makes a bulk ink system for it Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 or even maybe sublimation ink! Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted May 1, 2014 Try Cobra Ink they might be able to help on the ink. Share this post Link to post Share on other sites
jfought 120 Posted May 1, 2014 solventprinterconversion.com these guys are the bomb with these machines 1 Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 solventprinterconversion.com these guys are the bomb with these machinesthat is where I looked to find it wasn't able to be converted to solvent 1 Share this post Link to post Share on other sites
Rip_frannie 47 Posted May 2, 2014 Thanks boys. Think I need a print head for sure. Just want to get everything else straight before I put that in. Share this post Link to post Share on other sites
