atomicimprints 0 Posted January 30, 2014 Hopefully someone can assist me with a problem I'm having trying to contour cut using Signcut Pro. I have a Laserpoint 1 and I've installed the trial of Signcut Pro to test the contour cutting ability. I can cut regular designs just fine, no problems at all. But, when I try to calibrate the laserpointer for contour cutting, the cutter head will not jog. It draws the crosshairs (using the pen adapter) on a test piece, but when it ask me to jog the cutter head to line up the laser, it won't move. Even if I try to align the laser with the registration marks on a printed page (using the simple contour cut menu), the cutter head will not jog. But, if I close out of the laserpoint registration screen or simple countour cut screen, and I click the big "Jog" button in the toolbar, the cutter head will move. Doesn't make any sense to me....any thought? Share this post Link to post Share on other sites
scmaria 4 Posted February 3, 2014 Hi mate, Did you put in a support request about this to our helpdesk?If no, please do so. I think we better hook you up for a remote session to check what kind of communication you are using and make sure all your settings are as they should be Best Regards Maria Share this post Link to post Share on other sites
atomicimprints 0 Posted February 3, 2014 Hi Maria, Yes, I did put in a support ticket request. I've actually emailed back and forth with you a few times. Unfortunately, I don't know when I'll be available to do a live support session during the times available. If there comes a time available, I'll certainly check it out. Just thought I'd see if anyone on the message boards may have come across this problem and see if they had a solution. -Tim Share this post Link to post Share on other sites
digitalian 0 Posted March 28, 2014 Hi, I also have exactly the same problem hope someone has the answer Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 28, 2014 Have you contacted SignCut support? Those folks are great about getting you going. Sometimes they can walk you through it with a few emails or they will do a remote session and dial in if you are having any major issues. Maybe I am wrong but I think you can jog your cutter directly from the machine? I never had a laserpoint but I think it's a P-Cut based machine (which I did have). I never tried to do a contour cut so I am not a lot of help directly, sorry. Share this post Link to post Share on other sites
