coateslr 0 Posted March 24, 2008 (Copam 4050 48") I have vinyl scrolls that are 19" wide. I have the vinyl and place holders set on the green sections. Before I cut, I do a measure each time. The cutter will measure the vinyl all the way across from green section to green section. In order not to waste vinyl, I set up my pictures 18 inches horizontal by varying lengths, giving an inch of margin horizontally. The cutter will go no further across than 17 inches cutting off 2 inches of my picture every time. In my page setup, I have 18" x (whatever length I choose, usually over 13 inches) In my cutter setup, I have 19" x (whatever length) The only way it will print past 17 inches is on the lenght. I have checked and unchecked all of the settings such as weed all, fit to origin, etc. What is going wrong? Share this post Link to post Share on other sites
kenimes 42 Posted March 24, 2008 The Copam measures from pinch roller to pinch roller and retains the measurement setting when you tell it to cut. If it did not measure the full width of the material, you could have the pinch rollers too far in on each side of the material. Share this post Link to post Share on other sites
coateslr 0 Posted March 24, 2008 I will give it a try by setting the pinch rollers to the ends of the green sections which is near the end of the vinyl and let you know. Share this post Link to post Share on other sites
kenimes 42 Posted March 24, 2008 Ok, keep me posted. Share this post Link to post Share on other sites
coateslr 0 Posted March 25, 2008 That did the trick!!! Share this post Link to post Share on other sites
ddarby08 0 Posted April 16, 2008 I have been having the same issues and looking everywhere for a solution. It looks correct on signblazer prior to printing but then doesnt print all and cuts off. Im going to try this solution too with the pinch rollers. David Share this post Link to post Share on other sites
ddarby08 0 Posted April 16, 2008 Okay thats it. It works thanks alot for posting all. Its the pinch rollers! David ps did my first cut today. Big learning curve coming from ground zero. Share this post Link to post Share on other sites
