latitude42 5 Posted March 18, 2008 whenever I cut ANYTHING over say about 15" long... the vinyl will start to walk down the roller. I test to make sure it is true before I cut, but after I start cutting it starts to get crooked on the roller and nothing lines up. If I try something like 40"... forget it, when it cuts the initial box to weed it is about 1.5"-2" off when it gets back to complete the box. Any ideas on what to do? Thanks, Larry C Share this post Link to post Share on other sites
Popeye 0 Posted March 18, 2008 I added two more pinch rollers to mine and everything stays aligned My want to check blade depth and psi too... Share this post Link to post Share on other sites
latitude42 5 Posted March 18, 2008 I'll have to see if I can get a couple more rollers (and figure out how to put them in!!) My blade is adjusted right and I'm using pressure enough so that I can weed the stuff, usually around 170-175. Gotta do something. Larry C Share this post Link to post Share on other sites
kenimes 42 Posted March 18, 2008 whenever I cut ANYTHING over say about 15" long... the vinyl will start to walk down the roller. I test to make sure it is true before I cut, but after I start cutting it starts to get crooked on the roller and nothing lines up. If I try something like 40"... forget it, when it cuts the initial box to weed it is about 1.5"-2" off when it gets back to complete the box. Any ideas on what to do? Thanks, Larry C Have you tried cutting without the weed box? Share this post Link to post Share on other sites
mustangconv85 0 Posted March 18, 2008 so far i've only cut one long decal for my own windshield about 48in and for that i turned the weeding box off Share this post Link to post Share on other sites
firemalt 10 Posted March 18, 2008 What length of vinyl is on your roller? I had a bit of a problem with keeping things aligned when I would just sit my 50yrd roll on the rollers... I had to start cutting off the length I needed to cut until it didn't weigh so much. Share this post Link to post Share on other sites
latitude42 5 Posted March 19, 2008 I use 10 yd rolls... I've never turned the weed box off... actually didn't know you could. I'll look and see how.... thanks for the suggestion. Larry C Share this post Link to post Share on other sites
latitude42 5 Posted March 19, 2008 ............OK.........How do you turn the weed box off?? Thanks again, Larry C Share this post Link to post Share on other sites
go hodags 0 Posted March 19, 2008 when you are in cutter window, unclick the weed all box Share this post Link to post Share on other sites
kenimes 42 Posted March 19, 2008 You could also loosen enough material off of your roll before the unit starts to cut, so it is not pulling from a tight roll of material. Also make sure none of your pinch rollers are in the very middle of the cutter, or it will not make good contact with the feed rollers, and cause unwanted vinyl drift. Share this post Link to post Share on other sites
firemalt 10 Posted March 19, 2008 You could also loosen enough material off of your roll before the unit starts to cut, so it is not pulling from a tight roll of material. Also make sure none of your pinch rollers are in the very middle of the cutter, or it will not make good contact with the feed rollers, and cause unwanted vinyl drift. I've made both of those mistakes in my learning curve... Share this post Link to post Share on other sites
Guest sciondrgn Posted March 19, 2008 After lining things up I check movement first if I track to the right I adjust the vinyl on the left pinch roller back just a bit and opposite for tracking to the left. Just small adjustments I can usually get it it on the first or second try Share this post Link to post Share on other sites
signman911 1 Posted March 25, 2008 I tried to cut reflective vinyl 8 feet X 6 inch strips I put a roll of vinyl on the rollers 50 ydsX 20 inch I figured I could cut 3 strips 6 Inch X 96 inch I was striping a AMBULANCE the strips started perfect 6 inches but on the other end they were 6 and 1/4 I had to cut all the strips by hand Share this post Link to post Share on other sites
Guest Terry Posted March 25, 2008 $20.00 http://www.monokote.com/accys/topr2420.html http://www.hobbylinc.com/cgi-bin/s7.cgi?cat_s=&age=&str=smart+stripe&sort_i=&show_i=&flag=&also_s= Share this post Link to post Share on other sites
JoeCamaro 11 Posted March 25, 2008 Remember Always use the rulers in the front and back of the cutter. What I do is I align the vinyl and then move it forward and backward and make sure the vinyl moves over the same numbers I set the vinyl with. If you see movement, then it wasnt really aligned. Share this post Link to post Share on other sites
latitude42 5 Posted March 26, 2008 I've always done the align first thing, I usuall move the vinyl forward and back about 12-14 inches BEFORE I cut. It's during the cut is when its moving... I'm going to buy a couple of extra tension rollers. Thanks, Larry C Share this post Link to post Share on other sites
