DavidHamp
cutting siser glitter heat transfer
Has anyone had lots of experience with this stuff. I'm running a roland gx-24 and having a bear of a time getting it to weed out so any info on cutting settings would be great. I run flexisign for my cut program. i'm gonna try to do another one on 2 passes and see if that makes a difference.
I use it all the time (99.9%) I use a Graphtec, what problems are you having? Cutting or seeing the weed lines? Are you putting a border around your image? What degree blade are you using? I use a 60* for everything.
Mike
