SewDarnHot 0 Posted June 23, 2013 My copam is not able to cut what i need it to and customer support will not help me without a phone line so after hrs of designing something for the perfect fit I cant cut it. So I am looking for help. Can someone take my signblazer image and convert it into scal or at least to an svg file. Pretty please!!I have a cricut and can at least use that with multi cut and get it done. Dad Face PlateJune15_2013_a.SBD For some reason my signblazer will not export the file. Share this post Link to post Share on other sites
mb20music 759 Posted June 23, 2013 Try this... dad_plate_svg.svg Share this post Link to post Share on other sites
SewDarnHot 0 Posted June 23, 2013 Thank you very very much!!! Looks great. Share this post Link to post Share on other sites
SewDarnHot 0 Posted July 17, 2013 Try this... Is there a way you can try to join the middle bottom center line? I went to use it and it has a gap in the center section bottom. I should have test cut a while ago. I tried to add nodes but now i'm getting a skip in the cut corner and that center part needs to be removed for the customer. Thanks, I appreciate your help. Sorry for the long delay I had to wait for the vinyl to get here. Share this post Link to post Share on other sites
Donna111 0 Posted October 15, 2013 hI THERE i usually convert the image using an image converter,which supports to convert image effectively. But i've never tried to convert signblazer image before using this converter.I believe there is a third party program which supports to convert signblazer image.You can choose one. Share this post Link to post Share on other sites
