jfteague 0 Posted March 13, 2007 I just got my MH721this afternoon and am trying to install it. I can't seem to get the computer to communicate with it at all. I've tried parallel, serial, and usb (including installing the drivers) and nothing seems to help. If someone is around and can help I'd appreciate it! Thanks in advance! Share this post Link to post Share on other sites
TaterNuts 3 Posted March 13, 2007 are you using signcut? Did you address the ports correctly? Share this post Link to post Share on other sites
jfteague 0 Posted March 13, 2007 Thanks for the quick reply! I believe I did. I installed the new driver that was posted here in the forums this week. If self-installed I believe and I made sure it was assigned to COM2 and made the same settings in SignCut. Is there something else I need to do? Share this post Link to post Share on other sites
TaterNuts 3 Posted March 13, 2007 If your settings are as com port, then besure your connection is serial or the usb... I personally reccomend the serial connection as it seems the best. You are checking the status of the ports in device manager correct? Sometimes when you install a new perephial, windows will sometimes recognize it as another port besides com2... check under the ports in the device manager and you should see it there. It will probably not say "plotter" or anyting, it is most likely to say communications port. Be sure that the one in device manager matches the one in sign cut. If you are using the serial connection (non usb) you shouldnt have to install any additional software besides signcut Share this post Link to post Share on other sites
jfteague 0 Posted March 14, 2007 Thanks for the help! I just checked back in to let everyone know I believe I got it going. It's cutting but now it looks like I need to do some adjusting. The font I just tested was kinda small so it didn't cut cleanly and rip in some areas. I guess that will get adjusted with practice. Thanks again for the help and hopefully I'm operational for good now. Thanks again! JT Share this post Link to post Share on other sites
TaterNuts 3 Posted March 14, 2007 What was wrong? Maybe you could post it incase any others have issues. Share this post Link to post Share on other sites
Guest fivestar Posted March 14, 2007 Sounds like your blade depth is a little to deep or putting too much force on it. Share this post Link to post Share on other sites
