moss2029 0 Posted March 8, 2013 alright when i run small graphics and letters they become really rounded off. i have played with my offset all i can it only makes it worse no mater what value i use. Im running flexisign pro 10, and have a 45 degree blade. i have tried everything i can think of, can anyone with flexi help me out?? Share this post Link to post Share on other sites
mb20music 760 Posted March 8, 2013 Yes, that is the problem with the value cutters, they don't do well with small text. How small are you trying to cut? normally anything under 1/2" letters will give you problems. Share this post Link to post Share on other sites
slice&dice 2,451 Posted March 8, 2013 Just a thought, and it may not work, but have you tried cutting with either SCALPRO or SignBlazerElements? From what several users have said, the SCALPRO cutting drivers are superb. And I have always been satisfied with the results of SBE, down to about 1/2" Share this post Link to post Share on other sites
mopar691 281 Posted March 8, 2013 are you running a true copy of flexi? If not that could be a problem also. The cut engine in flexi is superb if set up correctly, Always found it weird running a three grand program on a 2 bill cutter, Slow your cut speeds way down would be my guess. 1 Share this post Link to post Share on other sites
egobuster1 9 Posted March 10, 2013 i would try a 60 degree blade also for the fine cutting stuff Share this post Link to post Share on other sites
skydiver22 6 Posted March 17, 2013 I would advise you to use 60 degree blades when cutting the small stuff with the MH.. I cut down to 1/4" letters with no problems with 60 degree blade. My 45 blades will not allow me to do that.. Share this post Link to post Share on other sites
egobuster1 9 Posted March 22, 2013 yeah my cutter is like night and day difference with a 60 degree blade over a 45 degree blade. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 22, 2013 PSSSST, it was a hit and run- not back on the forum since 3-8-13 at 321 am. Share this post Link to post Share on other sites
