Brunton850 0 Posted December 10, 2012 hello when i goto my production manager and goto connect my ce3000-mk2 , it doesnt show my plotter it only shows 3 others graphtec plotters , is there any way i can get mine to connect? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 10, 2012 what happens when you try one of the other drivers? Will 1 work? And your cutter will have to be on COMMAND HP-GL.. Have you gone to the Graphtec site and downloaded your driver? It is there in legacy cutters. It seems to be the same driver as I use. You may also be able to use the ALL CUTTER version of Signblazer and find your cutter there. Share this post Link to post Share on other sites
Brunton850 0 Posted December 11, 2012 Thanks i got my driver under the legacy cutters thanks to you , but once i install it , do i have to put any files anywere or is that it? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 11, 2012 Thanks i got my driver under the legacy cutters thanks to you , but once i install it , do i have to put any files anywere or is that it? Read thru the set up page with the file. I don't have your cutter. You should be able to set your cutter up in Flexi then. I use mine on USB with no problems. You can do that on the higher end cutters. But with Flexi , it has to be on Command HP-GL Share this post Link to post Share on other sites
Brunton850 0 Posted December 11, 2012 i have my cutter plugged in with a USB and when i still goto production manager after getting that driver , it still only showing the 3 as it did before , and the setup page doesnt really tell me much , just to install it and thats it have my plotter on command HP-GL Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 11, 2012 Did you restart your computer? And I asked you before, what does your cutter do when you set up on one of the other cutters? Did you even try them.? Many cutters work on the same driver.... Share this post Link to post Share on other sites
Brunton850 0 Posted December 11, 2012 yea i have done , and when i click on done or send , it does nothing atall ? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 11, 2012 yea i have done , and when i click on done or send , it does nothing atall ? Then ask SAI support, or ask Graphtec support. Or just maybe, it's time to update your software to something that does have the correct driver. Your dealing with outdated cutter and software. As I have already stated, the All Cutter version of Signblazer, should have the correct driver. Share this post Link to post Share on other sites
