sdavies 0 Posted August 24, 2012 I am pretty new to using cutters. I have an SC series cutter. I am going to try making rhinestone shirts and recently bought sticky flock. I go an additional blade holder to use for this. Do I set the blade just like I would for vinyl? Are there any other settings on the machine that need to be changed for cutting this material? Any advice? The only thing I have cut so far is Oracal 631 vinyl. Thank you for any help you can offer. I am excited to get started! Share this post Link to post Share on other sites
mfatty500 455 Posted August 24, 2012 Your blade should be out a little more than you use for any other vinyl, also you may have to make two passes. Start with something small so that you don't waste your sticky flock . Also remember that you will probably not see that is cutting or not. Hope this helps, I don't know anything about your cutters settings so some one else may have to chime in on that. Mike Share this post Link to post Share on other sites
