MAPTAT 0 Posted July 23, 2012 Really! I have been trying for a couple of long sessions to import a SVG file I made in Inkscape into SB. I can open the folder the SVG image is in and can see it and several other files. However, when I open SB and go to import and then look for the image within the saved folder, SB sees zero files. Doesn't see JPG, TIF, or the SVG. I did use the search function and can't find any info related to this specific problem. Help would be apreciated. I can go no further until I get that image into SB. Thanks. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 23, 2012 when you save your file in inkscape.. you must save as an .eps file for Signblazer. but also save the,svg file so you can edit it, if you want to later explains how to http://start.uscutter.com/software/inkscape 3 Share this post Link to post Share on other sites
MAPTAT 0 Posted July 23, 2012 Thanks for that url. But...it stops short of telling you to save both a SVG and an EPS file. I did save it as an EPS file. Open SB and select import and it shows the squares with different file names but the ones that I saved as an EPS type are totally black. I tried to load them anyway and after I follow the prompts, nothing happens. Share this post Link to post Share on other sites
Mx2 11 Posted July 23, 2012 Just go to file>save as ad then save as ***.eps after that saves go back to file>save as and save as ***.svg or just click save, or you can try to copy all of your objects and paste into signblazer that works for me it will group them but web you ungroup them it's everything you had in inkscape Share this post Link to post Share on other sites
MAPTAT 0 Posted July 24, 2012 Again... I did save it as an EPS file. Opened SB and selected import and it shows the squares of the items you saved in Inkscape but they are solid black. I can see the choices with different file names but the ones that I saved as an EPS type are totally black. I tried to load them into SB anyway and after I follow the prompts, nothing happens. Still at a standstill until I get past this. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 24, 2012 did you vector the image and delete the original image before saving the file? You must.. Share this post Link to post Share on other sites
MAPTAT 0 Posted July 24, 2012 Thought I did. Maybe I deleted the wrong one. But one time I used the node tool and saw all the nodes so it must have vectorized. Read somewhere else on the forum advice to remove both SB and IS and then re install, after a lot of suggestions and attempts at help which didn't improve anything. So...just got rid of both pieces of software and am going to reload them and try again. Share this post Link to post Share on other sites
MAPTAT 0 Posted July 24, 2012 I finally did it one time after I reloaded all the software. However, this AM, I am doing the same thing wrong. Yes! I deleted the original and saved the vector. Then I did a save as and selected EPS. When going into the folder and looking at that file it says it's a PVW, not an EPS. Why? Share this post Link to post Share on other sites
Mx2 11 Posted July 24, 2012 .pvw I a file that signblazer makes to interpret the file to display the image. Share this post Link to post Share on other sites
MAPTAT 0 Posted July 25, 2012 Mx2 stay with me on this. Still stumped. Does the same thing every time. When I open SB one of the boxes in which the 'cut' file is named is totally black. I look at that file and it says it's a eps. I import into SB, can see it, but when I tell the cutter to cut it I get a dialog box which says I'll lose some data because it can see a bit map and then states it can't print it as it's a bitmap. Share this post Link to post Share on other sites
cowboy_1_831 28 Posted July 25, 2012 Maybe you can post the file and we can see whats going on. Share this post Link to post Share on other sites
Jay2703 704 Posted July 25, 2012 Mx2 stay with me on this. Still stumped. Does the same thing every time. When I open SB one of the boxes in which the 'cut' file is named is totally black. I look at that file and it says it's a eps. I import into SB, can see it, but when I tell the cutter to cut it I get a dialog box which says I'll lose some data because it can see a bit map and then states it can't print it as it's a bitmap. That is telling you there is a bitmap image in the design. The cutter cannot cut bitmaps. Does anything show up in the cut window? Share this post Link to post Share on other sites
Mx2 11 Posted July 25, 2012 Mx2 stay with me on this. Still stumped. Does the same thing every time. When I open SB one of the boxes in which the 'cut' file is named is totally black. I look at that file and it says it's a eps. I import into SB, can see it, but when I tell the cutter to cut it I get a dialog box which says I'll lose some data because it can see a bit map and then states it can't print it as it's a bitmap. If you could email me the file in question for me to take a look at I'd love to help, Thomas.Guffey@me.com Share this post Link to post Share on other sites
MAPTAT 0 Posted July 26, 2012 Here are the files. First try in uploading them. Hope they get there. Thanks for everyone's help. firetry1.svg firetry2.eps Share this post Link to post Share on other sites
Signs Down Under 19 Posted July 26, 2012 The eps file you supplied isn't great but opens in SB no problem. Not sure what the trouble is !! Firetry2.SBD Share this post Link to post Share on other sites
