JennD26 2 Posted June 3, 2012 I tried searching the forum and I found similar threads, none of them seemed to help as the solutions weren't available. I am using a MH-721 and Adobe Illustrator (Previously Inkscape) When I create a design and print it I get little lines where the text connects. How can I fix this and make it one fluid design? I've tried welding and outlining but none of these options are available to me. I've included a picture of the design, though I'm sure you all know what I'm talking about. I appreciate any help or insight! Share this post Link to post Share on other sites
markvvq 14 Posted June 3, 2012 When you say print it are actually referring to cut it? If so does your cutting software have a weld while cutting feature? Share this post Link to post Share on other sites
JennD26 2 Posted June 3, 2012 Yes, I meant cut. I'm a complete newbie! I've learned everything I know so far through videos and reading other threads. I haven't noticed that feature. I am using SignCut Pro for my cutting software. Share this post Link to post Share on other sites
vinylmotivations 143 Posted June 3, 2012 When you create text, convert it to curves first, then weld, then cut... 2 Share this post Link to post Share on other sites
JennD26 2 Posted June 3, 2012 This worked, thank you! I really appreciate you taking time from your day to help me with this issue and my cutting issue!! Share this post Link to post Share on other sites
jhelms 5 Posted June 4, 2012 I know you have to weld it but over the weekend I was doing cursive fon t and messed up 4 ft of vinyl still have a hard time learning this lesson So I know what you mean good luck jhelms Share this post Link to post Share on other sites
